Think this is hurting or helping?
It's split in the middle, no idea what caused it, but seems it's supposed to be secured up higher and is sagging pretty badly, I can probably fix it easy enough. I have some thin stainless steel and aluminum at work, I was thinking about cutting a piece and using drilling some holes and using interior panel fasteners or screws to tie the pieces together and re-secure it.
It occurred to me though it may be action as a somewhat dynamic air dam, admittedly in all the wrong ways in regards to speed it's redoubtably being pushed up and out of the way but is surely directing more air around the front than it would be if it were secured as intended.
