01-15-2018, 04:10 PM
#804 (permalink)
Roy Spencer is a paid shill. He has no data.
Who is Roy paid by besides University of Alabama?
Apparently he does have data and presents some of it on his website.
These comments below suggest he understands the fundamentals of the greenhouse effect very well. He suggests that AGW models predict too much warming, and that might be accurate given the fact that some scientists have been found to be lying about their numbers to support AGW alarmism.
Greenhouse components in the atmosphere (mostly water vapor, clouds, carbon dioxide, and methane) exert strong controls over how fast the Earth loses IR energy to outer space. Mankind’s burning of fossil fuels creates more atmospheric carbon dioxide. As we add more CO2, more infrared energy is trapped, strengthing the Earth’s greenhouse effect. This causes a warming tendency in the lower atmosphere and at the surface. As of 2008, it is believed that we have enhanced the Earth’s natural greenhouse effect by about 1%.
Global warming theory says that the lower atmosphere must then respond to this energy imbalance (less IR radiation being lost than solar energy being absorbed) by causing an increase in temperature (which causes an increase in the IR escaping to space) until the emitted IR radiation once again equals the amount of absorbed sunlight. That is, the Earth must increase its temperature until global energy balance is once again restored. This is the basic explanation of global warming theory. (The same energy balance concept applies to a pot of water on a stove set on “low”. The water warms until the rate of energy loss through evaporation, convective air currents, and infrared radiation equals the rate of energy gain from the stove, at which point the water remains at a constant temperature. If you turn the heat up a tiny bit more, the temperature of the water will rise again until the extra amount of energy lost by the pot once again equals the energy gained from the stove, at which point a new, warmer equilibrium temperature is reached.)
Now, you might be surprised to learn that the amount of warming directly caused by the extra CO2 is, by itself, relatively weak. It has been calculated theoretically that, if there are no other changes in the climate system, a doubling of the atmospheric CO2 concentration would cause less than 1 deg C of surface warming (about 1 deg. F). This is NOT a controversial statement…it is well understood by climate scientists. (As of 2008, we were about 40% to 45% of the way toward a doubling of atmospheric CO2.)
BUT…everything this else in the climate system probably WON’T stay the same! For instance, clouds, water vapor, and precipitation systems can all be expected to respond to the warming tendency in some way, which could either amplify or reduce the manmade warming. These other changes are called “feedbacks,” and the sum of all the feedbacks in the climate system determines what is called ‘climate sensitivity’. Negative feedbacks (low climate sensitivity) would mean that manmade global warming might not even be measurable, lost in the noise of natural climate variability. But if feedbacks are sufficiently positive (high climate sensitivity), then manmade global warming could be catastrophic.
Obviously, knowing the strength of feedbacks in the climate system is critical; this is the subject of most of my research. Here you can read about my latest work on the subject, in which I show that feedbacks previously estimated from satellite observations of natural climate variability have potentially large errors. A confusion between forcing and feedback (loosely speaking, cause and effect) when observing cloud behavior has led to the illusion of a sensitive climate system, when in fact our best satellite observations (when carefully and properly interpreted) suggest an IN-sensitive climate system.
