Old 01-17-2018, 08:59 AM   #12 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
The lower grille's a lot bigger than the upper. Once you get instrumentation- an SG or UG that can show actual coolant temp, try blocking the lower instead. It should give you a bigger aero and warmup benefit, and if you keep an eye on the temps you may find that the upper still lets in enough air for cooling.
Transmission type Efficiency
