Old 01-17-2018, 02:25 PM   #202 (permalink)
cRiPpLe_rOoStEr
Originally Posted by BLSTIC View Post
It's only 12:1 I thought? That's conceivably gasoline range
At first the OP mentioned that compression ratio, but later mentioned that could go higher than that. But anyway, considering that such ratio is more frequently seen either in smaller-displacement engines which combustion chamber volume is inherently less sensitive to pre-ignition or in modern direct-injection engines, water injection is still not a bad idea at all.
