Old 01-17-2018, 05:40 PM   #7 (permalink)
chefdave
beastie - '89 toyota hilux dolphin motorhome
Puggie - '98 Peugeot 406 Lx
Cripple rooster is right about modern european cars. When i was delivering hire vans a few years back mercedes sprinters had a variable speed limiter. Hire company had these set to 65 mph. I worked out how to raise limit. Peugeot also have a variable speed limiter which you can set yourself. Must be easy if you have the knowledge to reto fit. They all worked of speedo reading. So if going up hill you could maintain speed and not be rev limited. Would suggest an ecu specialist or if buying new ask dealer if one could be factory fitted.
The Following User Says Thank You to chefdave For This Useful Post:
Isaac Zackary (01-18-2018)
