Old 01-18-2018, 02:37 AM   #15 (permalink)
WelshAdam
The lower grille's a lot bigger than the upper. Once you get instrumentation- an SG or UG that can show actual coolant temp, try blocking the lower instead. It should give you a bigger aero and warmup benefit, and if you keep an eye on the temps you may find that the upper still lets in enough air for cooling.
I also thought that, but on closer inspection around 3/4 of it is blocked with plastic trim - only the bottom two or so slats are actually open to allow cooling.
Definitely going to get a scan gauge at some point though, my car has an on board instant mpg display, but I do wonder how accurate they are. Still, better than guessing right?!
2014 Ford Mondeo Titanium X Estate, 2.0 turbo diesel... "the Bus".
The Following User Says Thank You to WelshAdam For This Useful Post:
Fat Charlie (01-18-2018)
