Dark Aero will be soon torn back down fer a new rebuild. The belly pan is programmed to be changed out to aluminum diamond plate with the ability to adjust and match the angle at the front.
Looking to smooth out the spare tire area under the truck and build some duct work under there and out through to the hitch. I might try to build out an exit duct between the back of the bottom gap cover so any airflow in between the belly pan and the floor pan will have somewhere to git funneled through.
