Old 01-23-2018, 04:59 AM   #7 (permalink)
Jez77
Originally Posted by interestingstuff View Post
Yeah, that's not an option. I bought the truck specifically to use it for transporting, and temporarily storing items in a secure manner. Basically assume that the use of the box truck is the same use as any other box truck would be.
Ok but can you afford to maybe loose some height in the rear maybe?
I had the idea of having the rear 1/3 of the box hinged in a couple of spots so it could be lowered if the space isn't needed. Most of the time the box isn't full anyway. I'd even be tempted to taper the rear sides in too if you can afford to loose a little width.
