Some thoughts about optimizing low and midrange torque
It may be useful for you to investigate using the Comp Cams Cam Quest program (free online) to learn about tweaking cam fitment for maximizing low and mid-range torque production. If you haven't already used this program, you'll see why it's being suggested. It can help with component selection. The GM TPI manifold is a gem for torque production. The second thought is using Total Seal zero gap rings. Give them a call and learn from people who can give experience-based advice on this area of efficiency - and longevity. The third thing is considering the use of Rhoads lifters on the intake side of your valvetrain. You will probably end up using a dual pattern cam, to compensate for the exhaust port's weaker flow (on Chevy small blocks' heads), so as a simple substitute for variable valve timing, you might find this useful. Just be aware of compression ratio/valve timing issues. Perhaps that is why you want to use the higher octane fuel. That may not be necessary - and you may not be so geographically limited by its availability - if you select your hardware combination carefully and keep a tight quench dimension. The people who race and develop engines are pursuing the same basic goal that you are - efficiency. They are usually not so concerned with longevity. :-) You can still use what helps you to achieve your goals and disregard the aspects that don't. This sounds like a worthwhile and fun project. Good luck with it.
