Old 01-23-2018, 10:03 PM   #71 (permalink)
ChazInMT
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Originally Posted by Angel And The Wolf View Post
Everything I've read says 15% is optimal for preventing slip stream separation You want the air to stay as close as possible to the skin to prevent turbulence
Sorry, gotta interject, First off, this is a flat cover, so the break from cab to flat cap top will really mess up any chance of keeping it anywhere near "Attached" at 15°. Secondly, the 15° thing is the Steepest you can be and not separate.....any thing Less....will maintain attached flow as well. Thirdly, The drag coefficient (Cd) between 5° and 15° (on an optimally shaped cap, will be within 5% of optimal.
So, As I've stated before, a 5-8° slope will yield the best results here, anything more will start to increase drag and cut into the usable space under cover.
The Following User Says Thank You to ChazInMT For This Useful Post:
slowmover (01-28-2018)
