Old 01-24-2018, 04:02 AM   #53 (permalink)
Natalya
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
If I recall correctly, the Insight is capable of running lean-burn until a certain intake temp is reached. Do you plan to remove the WAI in the summer, or do you not anticipate this being an issue?
The 2000 Insight has a fork in the air pipe leading to two intakes. I only re-routed one of the forks to the cat, so the other fork remains taking air in from its stock location. I did this on my first Insight in 2015 and with that vehicle I never had an overheating problem. On this one I went from the other fork to the cat, so maybe there will be a difference? I'll monitor the situation when it gets warmer outside.
