azraelswrd,
so you're saying i should let my tank go to 1/4, then fill up completely, then plug in my sg2? im just trying to understand so i get the best possible results.
i dont plan to turn my car off while driving it, but i have been wondering about the Deceleration fuel cutoff (DFCO) as you called it. does my 2003 cavalier have that? so i should stay in 5th gear when coasting instead of putting the car in neutral? i figured only more expensive cars would have this feature. my car is manual so i was putting it in neutral on long downgrades.
as for the adjustments, did you make those by using the sg2, and keeping track of your mpg the traditional way? then setting the difference in the sg2?
im excited to use it, but nervous im going to mess up the settings. i expect it to arrive on wensday!
