Old 01-25-2018, 04:28 PM   #5 (permalink)
Daox
If it stops, it is likely pinging. If it doesn't stop, it may still be pinging, and maybe not.
Seeing as you've checked all the OEM timing settings, I would think its probably not pinging. Have you checked for rattles? That would happen at specific RPM ranges. Pinging would more so be under heavy loads (lots of throttle).
The Following User Says Thank You to Daox For This Useful Post:
Xist (01-26-2018)
