Old 01-26-2018, 06:04 PM   #152 (permalink)
helpgeek
Thanks. I didn't scroll down far enough for the in the code to spot the LCD section. But I am still not sure about the injector.
In the original circuit diagram it says to connect the cable to the ground side of the injector. Is there any way I can connect the input to the injector signal from my vehile's ECU rather than run a cable to the engine bay?
My vehicle is a Holden Commodore VT using the Buick L36 3.8 litre V6 engine with Bosch EV6 injectors.
