Old 01-27-2018, 03:08 PM   #273 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by Phoenix'97 View Post
... I told you, engine swapping is out of the question!
I know. Everything that anyone has recommended that could actually work has been out of the question. That is why I said it was pie-in-the-sky dreaming.
You are planning on spending thousands to rebuild your ancient technology motor, put on wider tires, do no aero mods, refuse to change your driving habits, pay a crazy amount for alcohol fuel delivered by the drum (which has lower energy density then gas) and expect to get better fuel economy.
FYI, the Camaro automatics get better mileage and are faster than the 6 speed. You could likely buy a wreck with everything you need for less than you are planning to spend on your engine rebuilt. BTW, what is the price tag on this proposed rebuild?
The 6.2L auto does 2 mpg better in the city than your car which is a huge when the starting point is a dismal 15 mpg. MPG gains are not linear.
