Old 01-27-2018, 05:18 PM   #277 (permalink)
Phoenix'97
Phoenix'97's Avatar
White Steed - '97 Pontiac Firebird Trans Am WS6
I know. Everything that anyone has recommended that could actually work has been out of the question. That is why I said it was pie-in-the-sky dreaming.
You are planning on spending thousands to rebuild your ancient technology motor, put on wider tires, do no aero mods, refuse to change your driving habits, pay a crazy amount for alcohol fuel delivered by the drum (which has lower energy density then gas) and expect to get better fuel economy.
FYI, the Camaro automatics get better mileage and are faster than the 6 speed. You could likely buy a wreck with everything you need for less than you are planning to spend on your engine rebuilt. BTW, what is the price tag on this proposed rebuild?
The 6.2L auto does 2 mpg better in the city than your car which is a huge when the starting point is a dismal 15 mpg. MPG gains are not linear.
I have had disagreements on other car forums with members who insisted they had the correct solution for my desired build and that other options I was willing to try were wrong.
Even so called "ancient-technology" can be given a new lease on life when mated with newer technology. Just because something is brand new does not necessarily make it better than it's predecessor. I have enough suggestions from you guys on how to achieve the desired results I seek in balancing engine performance and "fun factor" with fuel efficiency, along with non-related mods to help further extend the life of the engine. So there I have it.
