Old 01-27-2018, 10:49 PM   #154 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by helpgeek View Post
Thanks. I didn't scroll down far enough for the in the code to spot the LCD section. But I am still not sure about the injector.
In the original circuit diagram it says to connect the cable to the ground side of the injector. Is there any way I can connect the input to the injector signal from my vehile's ECU rather than run a cable to the engine bay?
My vehicle is a Holden Commodore VT using the Buick L36 3.8 litre V6 engine with Bosch EV6 injectors.
You should be able to splice into the injector signal at your ECU, instead of at the injector.
