Old 01-29-2018, 04:53 PM   #79 (permalink)
Daox
It came with cruise control, but it was not enabled? What kind of numbers do you expect during warmer weather? As much as I like your grill block, would one out of foam board work better?
The DE trim does not have cruise available as an option. The ES (higher trim) comes with cruise control standard. However, the ecu has the programming already loaded, you just have to enable it. Add the correct switches, and it will work.
In warmer weather I am anticipating hitting 60 mpg.
I do think a foam block would be slightly better.
