Old 01-29-2018, 10:33 PM   #1001 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Adjust the pre load. 1+
If there ball bearings then up grade to tapered rollers they handle axial thrust better as well(the direction of bump thrust from pic above ). As the quote said adjusting the preload on balls is only temporary (as the hard crome plating has already warn through ) the balls are physically smaller/not round( probably) replacement is recommended. Call King Bearing in Fresno, Ca hart of ag land they have it on the shelf w/o dealer markups. But by all means inspect repack with" ball Bearing grease". They are difrent never use ball in roller!!! Ball is more of a fibrous chain that the balls massage. Where as the roller wraps them up like sticking a kitchen mixer next to somebody with long hair really quickly destroys the grease it becomes runny and leaks out as oil .
The harmonic that is responsible for the Caster wheel flutter we called tred squirm. Stiffer side wall helped, tall aspects raito tires hurt. Gives it that Cadillac flutter but feel that just doesn't feel right in a truck.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
BamZipPow (01-30-2018)
