Old 01-30-2018, 04:42 AM   #1 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Silicone Not Curing
I have twice torn into my Prius to repair a water leak at the joint of the firewall and front end. The previous time I just missed a section of the seam and water was still infiltrating the cabin.
This time, I hit the seam well with silicone sealant, and after the downpour today, not a drop of water made it inside.
The problem is that the sealant was way expired, and is failing to cure. A day later, it's nearly the same consistency as when I applied it.
I don't think I could clean it out and reapply new stuff due to how difficult it is to get to. I had to use a straw to apply it in an impossible spot to get to.
Any suggestions? Should I just put everything back together and hope it doesn't spring another leak? My fear is that once I hit the highway, air pressure will create a hole in the goop.
