I just ordered this $20 OBCII scan tool that you connect to with your iOS or Android divice via wifi.
http://amzn.to/2GwmCTt
I'll need to download a $5 app though to use it but if I like it maybe I'll find a used iPad or something to keep in the car permanently.
As for cutting up a lift gate; I suspect you'd do better to start with strips of flat sheet. What you're proposing is similar to the boxed cavity I mentioned in Permalink #48. Also the Koenig-Fachsenfeld (corrected spelling) tearing edges mentioned in permalink #28.
Exactly!
Two triangular fins from the outer edges down toward the taillight... ??
I can't see the photobucket image in the second link, either
I don't know why I didn't do this sooner but I looked up the drag coefficient for the Jeep Cherokee. Cd is a whopping 0.52!
Also, folks are saying that for a box cavity to be effective, air flow needs to be pretty smooth to begin with and a diffuser really helps.
http://ecomodder.com/forum/showthrea...uck-26367.html
Once the OBCII wifi scan tool arives in the mail, I'll make a cardboard mockup and do some testing...
Can this tell us anything??
