Old 01-30-2018, 01:52 PM   #19 (permalink)
ASV
weirdo
ASV's Avatar
a lot of white light LED are actually ultra violet LED shining through a micro dot florescent medium.
The medium will burn away over time leaving more and more UV and less white light. the amount of light being generated stays the same.
You just can't see it.
I believe this is caused by the relatively high intensity of UV
