Originally Posted by ASV
a large easy flow exhaust
exhaust insulation wrap
a constant flow low volume propane injector
a rear radial car tire
mild boost from an air amplifier
don't get your oil to hot or it will break down
hope that helps
Will try exhaust insulation wrap.
Thank you sir. Exhaust is a tubular style and straight through.
Propane injection would be good but no space for gas bottles!
Car tyre would be difficult on this bike as its tiny vs a car tyre.
A very small turbo running 3-5 psi of boost with no additional fuel would give 15% more efficiency I think, but I have no space for a turbo, only location I can have it is on the downpipe underneath the sump so would need scavenge pump etc. Too complicated!!
