Old 01-31-2018, 02:14 PM   #1014 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
If I had pursued this further, I would have gone toward a Vespa motor scooter front axle, with it's side-arm brake and suspension.
I wasn't sure whether the offset between the horizontal and vertical axis is important to your design or not. I leaned toward an horizontal hinge at the bumper and another hinge at the axle. If it was to fold up, the wheel would be on a 4-bar linkage.
Another possibility might be two vertical hinges, with [a] control arm[s] to control the side-to-side excursions. I'm not sure how that one would back up, it might want to jack-knife.
I'm still not sure the Vespa front fork setup will work in a reverse setup. The shock/springs are designed to compress and absorb the impact from the front. I don't see how well the springs will compress when the force is from the rear.
I would believe that the suspension would have to be more like the trailing rear suspension.
Dark Aero-The world's first aerodynamic single wheel boat tail!
