Old 02-03-2018, 10:13 AM   #28 (permalink)
Piotrsko
Laptop batteries don’t weight hundreds of pounds.
The pack in my Spark is 475 lbs split into 5 modules. To make the modules swappable the power, battery management, and cooling would need to be plug and play. Then the owner has to crawl under the car and drop a 100 lb module.
Ever rebuild an aircooled VW bug motor? Or how about dealing with a Volt pack? Everything is quick disconnect and easy just using a floor jack. Not something a rocket surgeon needs to do, but average Joe can.
