Old 02-04-2018, 10:50 PM   #75 (permalink)
cRiPpLe_rOoStEr
Basically you'd want to try the opposite of a motorcycle shifting pattern... But relying on paddle shifters instead of a H-pattern shifter wouldn't effectively allow you to go directly through 6th to 1st, even though with a clutch pedal you could try to emulate it (but it would take longer than simply going from 6th to 1st with a stick-shifter).
