Old 02-06-2018, 03:22 PM   #8 (permalink)
Angel And The Wolf
the side view is butchered. IMHO it should also slide forward to match the contour at the roof.
Beard, I used the portion of the profile from the highest point (widest point when laid horizontally) because I didn't want to cut off part of the rear fenders to match the profile. Nor did I want to add width to reach the profile. Yes, that would be more tear drop, but I'm giving up the profile forward of the rear corners of the car, and using it from that point back.I can post the unbutchered profile on the top view: (You know, I think you may be right!) Thanks!
Name:	2011 Prius redone top view.jpg
The Following User Says Thank You to Angel And The Wolf For This Useful Post:
BamZipPow (02-06-2018)
