Old 02-06-2018, 02:57 PM   #14 (permalink)
easythereturbo
Yes, even at 120V 12A (the Bolt EV can be toggled between 8A and 12A on 120V EVSE units), it would take too long to charge 110 miles. That could take 20-24 hours.
No what I say is this, you can charge at
********TWO HUNDRED AND FOURTY VOLTS**********
At 12amps on the included charger. Yes the "110v charger" charges at 240 volts! Really. I know, I doubted it too but it does. That doubles you to 8 miles per hour.
Say you get home from work at 7pm, and leave for work at 7am, that is 96 miles per night. That would work out fine for a 110 mile commute. Total out of pocket less than $100 for the prong adapter cord, assuming you have the electric clothes dryer outlet.
My parents put in a 240v outlet, I think it was $1000 total to have an electrician do it right. Theirs needed to be in just about the worst place on the property relative to the source.
99% bev now
1% other junk
The Following User Says Thank You to easythereturbo For This Useful Post:
aerohead (12-05-2018)
