Originally Posted by Ecky
If I'm not mistaken, the fog light and high beams are traditional halogens, while the low beams are HIDs.
2004-2009 some option packages had HID in reflector(!) housings.
2010-2015 Trim V (2010) or Five (2011-2015) had LED lowbeam projectors.
2016- all trims have LED low- and highbeams.
The OP's car has halogens all around. There is a warranty enhancement program for 2010-2011 Priuses which replaces the headlight wiring harness with an updated version that should prevent premature bulb failure; you should check with a local dealer to see if it's been done (it probably hasn't).
