Old 02-07-2018, 01:39 AM   #9 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by Vman455 View Post
2004-2009 some option packages had HID in reflector(!) housings.
2010-2015 Trim V (2010) or Five (2011-2015) had LED lowbeam projectors.
2016- all trims have LED low- and highbeams.
The OP's car has halogens all around. There is a warranty enhancement program for 2010-2011 Priuses which replaces the headlight wiring harness with an updated version that should prevent premature bulb failure; you should check with a local dealer to see if it's been done (it probably hasn't).
Hah, what is the harness "upgrade"; a long spool of wire so it has a higher resistance?
My 2012 came with projector halogens. I replaced the halogens with a super cheap HID kit (like $35/pair) and it works well. Better than the halogens anyhow. The high beams are a separate bulb, so no change to them. My daytime running lights are LED from the factory.
