Old 02-07-2018, 08:04 AM   #6 (permalink)
S Keith
It means you've given the car plenty of opportunity to charge without subjecting it to high current and are minimizing the risk of killing cells at low SoC.
If the car runs normally otherwise, then it's probably okay to drive 15 miles. The biggest risk is if the 12V charging system is inop.
NOTE that when starting with the backup starter, it can take several seconds with the key in the start position before it engages.
