Old 02-07-2018, 03:07 PM   #7 (permalink)
Angel And The Wolf
Originally Posted by Old Tele man View Post
Typical causes for lamp failure are (in order):
1) Mechanical failure, ie: filament breakage.
2) Thermal failure, ie: over-heating due to too high voltage.
3) Intermittent -- ie: sudden ON/OFF -- current surges.
When a bulb goes out, and I can't slap it back on,Toyota finds filament breakage. I asked them what could be done to stop this from happening, and they suggested a different type of headlight that costs a couple of hundred for each side. Is there a plug inreplacement bulb that is less prone to breakage, and doesn't cost hundreds of dollars?
