Old 02-08-2018, 11:27 AM   #47 (permalink)
Isaac Zackary
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
Originally Posted by BLSTIC View Post
Proper programmable ignition with maps and all? I'd be very curious to see the results of just that, separate from the jet-a-vator. What carb do you run and can you post any pics of the venturis in it?
I'm using what's known in the VW world as a Solex 34-4 carburetor, which is practically the same as the very common 34-3 carburetor, both used on 1600cc aircooled VW engines, except the 34-4 has a thermostatic two step accelerator pump. The one and only venturi in it is 26mm in diameter. You can find pics all over the internet of the Solex and other brand 34-3 carburetors.
First I'm setting the ignition timing map to match that of the original that went with this engine. I couldn't find the exact match but this one seems close enough:
After that I'm working on AFR's first before diving into tuning the timing map. This is because the AFR will affect the proper timing since the AFR changes the flame speed. (It's very common for to hear of guys that bought a mechanical advance distributor without any vacuum advance that end up having to enrich the AFR to make the car drivable due to the lack of ignition timing.) I already ordered a smaller pilot (idle) jet, a 50 instead of the 55. I'm sure I'll have to go even smaller, but I thought I'd start there. Basically I'm aiming for a 17:1 AFR at low loads and want that to jump to 13:1 at high loads. Supposedly the Jet-A-Vator will also cause a leaning effect.
After the AFR's are dialed in it will be time to set the timing map for best torque and efficiency at any moment while not causing any pinging.
This is how one VW expert puts it:
What is needed is to find the timing point at EVERY RPM point where you are around 4 degrees retarded from detonation under full throttle, since this is the “ideal” time for our spark to occur.
VW Distributor Options « VW Parts - Aircooled.Net
