Originally Posted by sser2
Flow restrictor of this kind will worsen fuel economy because it will reduce air flow speed where it matters most: at carburettors Venturi. Economy can be improved by fitting carburettor with smaller bore, but of course at the expense of performance at high engine speed.
Two-barrel carburettors combine the advantages of small bore at low speeds and large bore at high speed.
If gadgets like this were really effective, they would have been standard on all carburettors 70 years ago.
Many late model carbureted cars did get grids under their carburetors for emissions purposes.
I don't see how it slows the air speed through the venturi, except at high RPMs and throttle. If it slowed it at cruise it would not be able to keep the same speed. It can slow the air speed around the throttle plate, but the grid should make up for that.
