Originally Posted by Vman455
I'm going to stop you right there: if you put tufts on the rear window and go for a drive, you'll see that there is attached airflow already over the back of the Prius.
True, but below and aft of the spoiler, there is a large draft area that I'm trying to fill in with a template shaped boat tail. I want a draft area slightly larger than a license plate. The clear cover over the hatch is in place of removing the rear wiper and spoiler, and to more closely follow the template.
