Originally Posted by aerohead
I would recommend that you put your effort into cleaning up the belly and rear wheel openings to guarantee quality flow to the boat tail.Then see if you can figure out how to get the 'final' diffuser angle as close to 2.8-degrees as you can.
My problem is that a 2.8 degree angle on an extended tail piece will drag on driveway ramps. Maybe doing the 2.8 degree thing, and hinging the tail at the spoiler, and raising it for those abrupt grade changes?
