A quick update. Finally found the 1.5" x 3.5" steel tubing I needed for the main frame structure, which welds onto the MC steering head's. I'm STILL trying to find another "Long Side" club Car rear axle and housing, to be able to finish the drive sprocket assembly. I also had to do a battery hack on my Chevy volt battery section, I needed 24v's to run a water pump at our mine, and being 300' vertical and 1/4 mile in without a trail, lightweight and lots of energy were required. It worked great, and the battery was still charged after several years of it sitting, I'm impressed. So long for now.
