Old 02-15-2018, 10:57 AM   #7214 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by jbman View Post
So, I reversed the TX and RX lines and got some garbage outputs like I did before. I should have mentioned it that earlier. I made a wrong assumption that I was getting garbage because it was crossed.
OK. I'd rather see garbage than nothing since sometimes I just have the baud rate wrong
Paul sent me the software for the new board just now (woohoo!). I have the throttle hooked up properly and the serial connections set up. When I get home tonight, I'll give it a whirl with the correct software.
Can you (or Paul) send me a copy?
Paul is not known for judicious backups (!!)
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
