Old 02-18-2018, 12:18 AM   #5 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
This is what I mean by roll scrub
Of corce the sight wants the picture sideways, ough.
I don't think it will add much if any strain on the system. Only side effect I can see is the single fixed Tire having a tendency to try and turn. similar to how you steer a motorcycle by leaning ( even drag bikes with 12" wide back tire that is square as a car tire still leans to induce the effect I'm speaking of, for turning).
Any ill effects would be most noticeable while high G-Force turning or severe side wind that causes body roll.
The greater the distance from the Roll center of the car and the U-joint Mount point the greater this effect will be. The Pivot Point must be at a central location as per the body shape and proportions through design you may be able to cheat this location towards the Roll center to minimize any ill effects. This is along the lines of what I was thinking as far as being able to do a one wheeled trailer behind a motorcycle/ bicycle.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
