Old 02-19-2018, 03:26 PM   #16 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Originally Posted by Angel And The Wolf View Post
Why would a two wheel trailer not have this problem?
1) Two wheel trailers have free movement in all three axis. On military equipment where this Roll center difference between trailer and truck can be very severe they use a pintle hitch where the ring is on a swivel(can spin 360°)on the Y axis.
2) roll from the tow vehicle is only seen as a change in Direction not a steering input such as in the y-axis lockout causing the tire to roll up on its side / lift one corner of the tire by changing the amount of weight on that section of the tire it changes the diameter / circumference from one side to the other. Somebody correct me if I'm wrong but I think that's why aircraft tires are so balloony, so that when the plane lands with excessive yaw the tires physically getting smaller where it wants to grow and the tires getting physically larger where it wants to shrink the circumference counteracting the tendency to Be a steering input.
The effect should be minimal and only a consideration. Motorcycles do not have to lean but 5° or less to change lanes no steering inputs involved.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
