Old 02-22-2018, 11:42 AM   #32 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by California98Civic View Post
Another cool thread. I just replace my bike charger. But first I investigated. The insides were mostly greek to me. I want to learn though. I'd also love to learn how to safetly adjust voltage. I have a 12s lithium battery. Most of the cheaper chargers are about 1.5 volts below what I need because they are for 10s lithium.
Look for a mini "pot" (potentiometer, in other words a variable resistor), usually near the output wires. Turn it one way or the other with a small screwdriver. Look like this, though maybe only 1/4" or smaller across:
You might "cook" the charger like I did, mind you, as you can probably expect a lithium battery to suck down the amps faster than a cheap lead-acid charger will want to put out. Might not too. Should be OK with one meant for lithium.
You can probably get away with one made for slightly higher voltage, seeing as your BMS should determine when it's time to cut off the power. (Err...do this at your own risk, mind you!)
Never mind on most of that; found your thread again!
The Following User Says Thank You to Stubby79 For This Useful Post:
California98Civic (02-27-2018)
