Old 02-23-2018, 05:41 PM   #159 (permalink)
josemapiro
Hi t vago
This new version has some problems the first one after entering settings there is no way to exit the settings using only the three buttons. The other problem I have is in the interrupts you are using in this version, INT4 and INT5, but I had combined using the mega 2560 version the INT2 and INT3, to avoid the problem of deep sleep.
For the settings you can add a line with "Back to Menu" or just "Menu" to allow you to exit the settings.
Thanks
José Rodrigues
