Originally Posted by spacemanspif
I think and impact will be minimal. Once I get it aimed I think I’m going to pack foam under the bar to create a less textured front end. Not sure if trapping can happen under the bar as it approaches the blocked upper grill. Plus the plate attaches behind the grill and there is now a small crack between grill and bumper that is leaking air (I assume) and will need sealing of some sort.
You're probably placing it where it will do the least harm.
It's a full-separation structure,but the cars nose will be training behind its wake.Since the area around it is in the best pressure gradient on the car,the separation will be limited to only very close to the unit.
Walter Korff and Sighard Hoerner published Cds for shapes like this,but I don't have that with me here.
