Old 02-26-2018, 05:32 PM   #394 (permalink)
freebeard
I'd call those all the wrong places and cite aerohead (92012)
I want to tread lightly here,but according to boundary layer theory,once critical velocity is attained,and the boundary layer is turbulent,all structures will follow the 115-degree rule,regardless as to whether they're a plane,car,or submarine.
If air,or any 'fluid' is attacking a particular curve,of any given radius,if 'zero' is the forward stagnation point,the 'fluid' MUST separate at 115-degrees of rotation beyond the stagnation point.
Example: if an analog wristwatch is moving from right to left,and the air first strikes at the 9:00 position,the air will not be able to remain attached beyond 4-seconds after 12:00.By the way,the angle at the separation point is 22-degrees.
Not to put my own spin on holy writ, but I interpret '4-seconds after' as the second hand being at 115° (60/4=15: QED).
There is a ring of dimples that are effective on a golf ball, the others are along for the ride. Like the rear-facing ones on the tail and fenders, and in the high-pressure bubble at the base of the windshield. IOW all of them. The doors and roof would be targets of opportunity.
You can't be wise and in love at the same time. -- Bob Dylan
