Old 02-28-2018, 12:56 AM   #1034 (permalink)
redpoint5
90 day: 29.78 mpg (US)
Originally Posted by All Darc View Post
I see such cells in flexible solar sheets. But in some home made flexible solar sheets using these cells, I see no metalic plate/sheet to absorb heat or take away heat. Overheat tend to reduce efficiency, am I right ?
Correct. Generally the colder the panel, the more efficient it generates electricity.
The best environment would be atop a high desert mountain near the equator.
I've always wondered how solar panels are cooled in space considering there is no air to transfer the heat. The only way it can reject heat is to radiate it or to conduct it to something else that then radiates away the heat.
