Old 03-01-2018, 01:46 PM   #12 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Most of the times a 6th gear is worthless at all, and sometimes a 5-speed transmission may actually lead to a better mileage compared to a 6-speed. But anyway, instead of a taller 6th, if I had the choice I'd get a wide-ratio transmission with a higher gear spread and match it to a higher differential.
Yea I'm doing the opposite in the Miata. I'm doing a really short geared 6-speed swap (gears 1-6 are actually shorter than the 5 speed 1-5), but I'm pairing it with the tallest rear end available for the NA Miata (3.63 instead of 4.1) So my 1-5 is the same ratio as the 5-speed with 4.3 rear end, but 6th gear is a true overdrive and makes driving the car a dream. My RPM will drop about 500 over the 5-speed with 4.1 (from 3636 at 75 to 3150(ish), and 750rpm over the 5-speed with 4.3.
The Following User Says Thank You to Baltothewolf For This Useful Post:
redpoint5 (03-01-2018)
