Originally Posted by red91sit
Aero Warriors - The <I>Scoop</I> On The Scoops
This is the most comprehensive explanation of the superbird / daytona's fender vents. I also vaguely remember hearing that these vents were designed to help remove rubber build up on modern racing cars with their ultra soft rubber compounds.
This is an interesting article. If anyone else reads it, note that the author's speculation about the fender louvers on the (then-current) 1999 Viper (actually, they appeared in 1996 on the GTS and 1996.5 on the RT/10) is incorrect. The plastic wheel well liner above the tire is solid, and those louvers cannot vent wheel well pressure.
However, the prominent side vents were/are open to the engine bay and wheel wells; the back part of the wheel well liner there is a rubber flap (just visible in the photo above), which may have served to alleviate wheel well pressure.
![](https://cdn1.mecum.com/auctions/ln1117/ln1117-319536/images/03-1507133681569@2x.jpg?1508163698000)
