I agree about the plasti-dip... could save you some time and get you tuft resting quicker... another positive is that if you went that route you could adjust any deficiencies you found in tuft testing, before you did any glass work...
A caution though, plasti-dip is usually thinned with either xylene or toluene, so go light on first couple coats to help avoid damage to the foam
My current Ecotec project...
My last Ecotec project...
