Old 03-08-2018, 03:17 PM   #16 (permalink)
19bonestock88
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Originally Posted by mpg_numbers_guy View Post
So I take it that the increased MPG of the 7th gen HCHs is less due to the electric assist and more due to the lean burn and taller gearing?
True, but both sound like one heck of a challenge lol.
Are you saying I can have the ECU computer reprogrammed for lean burn and to somehow make the manual tranny work as an automatic?
A significantly greater than 10% improvement for just one mod. wistfull look
The HCH1 also has a much smaller engine(1.3L) making much less power than your 1.7L...
You may be able to use Hondata to reflash your ECU and add in lean burn at cruise and alter shift points of your trans, which *could* gain you between 10 and 20 percent... an HX swap, while more involved, could gain you a little more...
The HX manual trans has better gearing than your auto does I imagine so the trans alone would get you something...
My current Ecotec project...
My last Ecotec project...
