Old 03-09-2018, 01:46 PM   #8 (permalink)
19bonestock88
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
I like this one:
LiFePO4 Prismatic Battery: 12.8V 20Ah (256Wh, 10C rate) (24.0) - UN38.3 Passed (DGR)
Keep in mind it isn't to be charged when below freezing, so hopefully locating it inside the cabin will prevent that situation.
Radio shouldn't matter much, but you should replace your lights with LED. Don't bother with the blinkers though.
If you buy from batteryspace, there are usually 10% off codes that should at least cover shipping.
Keep in mind this battery likely has half the capacity of your pb battery when it was new. It can handle deeper discharging on a regular basis, but doesn't like very deep discharging.
Can’t charge it below freezing? That won’t work, as I park outside and my cabin can remain below freezing several minutes into my commutes... I do wanna go LED for my lights and a switchback led for my front turn signal/ DRL... trying to find a decent LED 9007 bulb, as projectors are a little too rich for my blood at the moment
My current Ecotec project...
My last Ecotec project...
